Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
This command provides values for brouter port implementations. For IP protocol-based VLAN interface statistics, use View the OSPF Interface Statistics.
  1. To enter User EXEC mode, log on to the switch.
  2. Display extended OSPF information about the specified port or for all ports:
    show ports statistics ospf extended [{sub-port]][,...][slot/all][all]}]
Display extended OSPF information:
Switch:1>enable
Switch:1#show ports statistics ospf extended
                            Port Stats Ospf Extended
PORT_NUM RXLS_REQS  TXLS_REQS  RXLS_ACKS  TXLS_ACKS
1/3      0          0          0          0
Use the data in the following table to use the show ports statistics ospf extended command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
